Xpel Project on RMM Bumper
Old 06-16-03 | 02:17 AM
RMMGS4's Avatar
RMMGS4
Northern California Regional Officer
Default Xpel Project on RMM Bumper
Jawnthen and I custom cut our own Xpel for our RMM bumpers. You can see how much gloss the Xpel adds to the bumper. It even appears shinier than the non-protected section on the left side of this picture.
Old 06-16-03 | 02:21 AM
RMMGS4's Avatar
RMMGS4
Default 3rd time's the charm (Ready for CARSON)
Here's the area around the intake ducts. This is the 3rd iteration and the fit is now pretty good. Now I see why Xpel charges so much for their pre-cut pieces. You can waste a lot of expensive material trying to get the fit this precise.
Old 06-16-03 | 02:26 AM
RMMGS4's Avatar
RMMGS4
Default Template
This is the template that was created from cutting a raw stock roll of 3M film, the same material used by Xpel. The material was cut using a knife blade and a very steady hand. The material was cut against the plastic shown in the background.
Old 06-16-03 | 02:45 AM
jawnthen's Avatar
jawnthen
Default reasons to get xpel
so your bumper won't look like this
Old 06-16-03 | 02:58 AM
jawnthen's Avatar
jawnthen
Default before we put the xpel on....
clean up the bumper a bit
clockwise from top left: green spot putty on all pits and scratches, primer coats and wet sanding, final spray of metallic paint and clear coats, finsihed job ready for xpel
Old 06-16-03 | 04:31 AM
RMMGS4's Avatar
RMMGS4
Default Re: reasons to get xpel
And as for those nasty scrapes on the bottom, we have both alleviated that problem as well:
https://www.clublexus.com/forums/sho...threadid=86621
Is it any wonder that you've since lowered your car to "Synergy" levels?
Old 06-16-03 | 09:49 AM
AROD's Avatar
AROD
Do you have a link or more imfo about expel? That came out good.
Old 06-16-03 | 10:32 AM
RMMGS4's Avatar
RMMGS4
Just do a "Search the Forums" for Xpel or try the Xpel website. www.xpel.com.
Old 06-16-03 | 11:45 AM
redgs4's Avatar
redgs4
I'm still in awe of how well you color matched and painted the bumper using spray cans! Any chance of finding "cinnabar" in a can?!
Old 06-16-03 | 01:05 PM
CIPHER's Avatar
CIPHER
WOW!! How did you wet sand it? Did you take it somewhere or did you do it yourself?
Old 06-16-03 | 01:19 PM
LEXISM's Avatar
LEXISM
Thumbs up HOW DID YOU DO THAT ?
Did you really paint that w/ spray cans ? I'll do my front end this week end. I have a black 99 GS 400 do I need to say more
Old 06-16-03 | 02:32 PM
PHML's Avatar
PHML
Master Thread Closer!!
What Dupi-color code did you use to match the OEM paint?
Old 06-16-03 | 04:00 PM
RMMGS4's Avatar
RMMGS4
Chris,
just ask and you shall receive. I know where we can get cans mixed locally. For everyone else, look for an automotive paint supply store and ask if they can mix paint and put it in spray cans.
Both Jawnthen and I have spray canned several pieces, with surprisingly good results.
The Duplicolor code is T191 Ultra Silver. It IS NOT the factory color but very close. We actually matched our parts better than what the body shops did when the parts painted the first time.
Explaining in detail what we did will take more than just a couple of lines, but basically after priming and sealing, we sprayed 2-3 color coats and then 3 coats of clear. Then wet sand progressively with 600, 1500 & 2000 paper and hand buff with Meguiars or 3M scratch remover. No rubbing compound or machine buffing was done.
Those who want to check it out, we'll both be at the Carson meet this Saturday.
Old 06-16-03 | 04:18 PM
rominl's Avatar
rominl
exclusive matchup
CL Folding 10,000
and if someone is interested in getting xpel, i can refer you to my friend
Old 06-16-03 | 04:22 PM
AROD's Avatar
AROD
Hook me up with Xpel Romini.
