Skid Plate Project
#121
Alexus_300...how did you weld polyurthene to metal?
Also...why'd you drill two holes on the bottom?
I know in RMMGS4's version, he drilled 2 holes on the bottom his metal bracket so they can be attached onto the polyurthene piece
#124
I'm not sure where you're looking at to come to the conclusion that I'm welding polyurethane to metal.... Because I didn't do that anywhere on my brackets. The two holes that are drilled on the bracket is for me to bolt on my jack support that I attach onto it so when I'm on the track. That way I can just use my jack to lift the front end up easily to change brake pads and such. For everyday driving, I bolt on the Delrin pieces to avoid scratching the front end.
#125
very interested in this, i want to go as low as possible without worry, someone who's already done or has spares, i don't have the resources to have them made where I'm at so i can buy the pieces from someone and have them put on here, just wondering though anyone doing 3 up front, like one in the middle?
#126
#128
#129
Northern California Regional Officer
Here’s the skid plate I made on my wife’s car almost 7 years ago. The black plastic is “Delrin”. A great material to us as a skid plate.
I provided fabrication pictures on this link. There's just enough info for someone with skills to make it themselves or have a shop do it for you.
https://www.clublexus.com/forums/is-...tml#post764921
#132
#133
I'm 100% sure if the towhook size of the 2GS and 1IS is the same, but I believe it is. Therefore, the bracket should fit both cars...however, I think I might still have to change the design of the bracket a little bit to fit it inside. I think it's hitting the inside of my bumper a little bit...
#134
Tow hooks are the same size. If I'm going to get these things made, I need to get a accurate head count so that I can make them all at once. I don't really have the time to make one each time someone wants one.
