Evap leak gas cap?
Old 09-01-17 | 06:52 PM
GeorgeGS3's Avatar
GeorgeGS3
Default Evap leak gas cap?
Platinum 2000 gs300
it has turned on for the third time, what should I do?
Old 09-01-17 | 09:34 PM
Kris9884's Avatar
Kris9884
The gas cap is the best case scenario. In most cases its the valve on the charcoal canister under the gas tank, search the codes, its been reviewed and even has a DIY on the repair.
Old 09-01-17 | 11:40 PM
tmf2004's Avatar
tmf2004
5% Club. Killing it!!!
I've had the same code for months. "Evaporative Emission System Vent Control Circuit".. More than likely the valve.
Old 09-02-17 | 06:19 AM
fperron's Avatar
fperron
In my case, it was a broken rubber tube between the fender and the engine where the tube runs under the engine cover.
Old 09-02-17 | 02:08 PM
AmanO's Avatar
AmanO
I am gonna utilize this thread to specify.
My codes are coming on very shortly after I put gas in.
Then I can drive most/all of the tank without it coming back on.
I have already swapped the filler cap.
Would this trigger the valve sensor or do I have a leak in the filler neck?
Old 09-02-17 | 05:20 PM
tmf2004's Avatar
tmf2004
I replaced the almost 20yr old gas cap today. Probably didn't solve anything but its worth replacing.. I could tell the rubber was worn compared to old one and when i took the old off i didn't really hear any suction noise...
GoodRevs
12
01-14-24 01:43 PM
MellonC00
RX - 1st Gen (1999-2003)
06-24-20 11:51 AM
akafixture
04-28-16 03:20 PM
Bax
12-17-13 08:34 PM
XavierGS3
02-10-12 06:19 PM
Quick Reply: Evap leak gas cap?
