taller tires in the back ?
hello everyone ... my 98 gs400 curing have 350z 18" wheels on right now and with 235/45/18 all around , but the rear tires are worn out and i want to go with 235/50taller/18 for the rear... is there any problem fi i go with taller tires in the rear?
There's another thread in here that talks about how the ABS can get screwed up by a tire circumference mismatch between front and rear. You'd have to check that thread to see if the difference you mention is enough to cause a problem.
