Advice for P0440 P0441 P0446
Old 09-21-17, 06:58 PM
tyson rust
tyson rust's Avatar
Default Advice for P0440 P0441 P0446
i have a 2001 Gs300 245k miles. i have a check engine issue when i check it 2 problems arise i want some advice , the computer said charcoal canister filter, which is a 500 part or could it be idle air control motor? reading said two different things please advise
Old 09-21-17, 07:37 PM
Mr Jokster
Mr Jokster's Avatar
Whats the code?
Most likely its the purge valve, a $20 part on ebay. The canister rarely goes out, its the valve that is exposed to the elements to where it gets stuck open or closed.
tiguy99 (08-06-18)
Old 09-22-17, 07:50 PM
tyson rust
tyson rust's Avatar
idle air control it also said disfunction or intermittent if that makes sense?
Old 09-22-17, 07:52 PM
tyson rust
tyson rust's Avatar
Originally Posted by Mr Jokster
Whats the code?
it read idle air control &also misfunction or Intermittent hope that makes sense?
Old 09-23-17, 12:11 AM
Mr Jokster
Mr Jokster's Avatar
Whats the code please!
tyson rust (09-27-17)
Old 09-23-17, 08:53 AM
kevin3344
kevin3344's Avatar
Sounds like the Idle Air Control Valve (P0505)...the charcoal canister code pops up a lot many times could be something as simple as your gas cap. Dealer wanted $800 to replace my charcoal canister (for the second time) and I just waited and the code went away.
Old 09-26-17, 10:09 AM
tyson rust
tyson rust's Avatar
ok sorry for the delay the code read p440 p441 p446
gohanzfree (10-31-17)
Old 09-26-17, 11:59 AM
kevin3344
kevin3344's Avatar
Yep, sound like your purge valve...also look around for cracked vacuum hoses.
The following 2 users liked this post by kevin3344:
gohanzfree (10-31-17), tyson rust (09-27-17)
Old 09-27-17, 02:30 PM
tyson rust
tyson rust's Avatar
there are a couple of valves which one in particular?
there are the following pcv valve
there is a ego vacuum solenoid valve
vapor canister purge valve
Old 10-07-17, 10:14 AM
try714
try714's Avatar
Did you solve the issues?
Old 10-11-17, 10:37 AM
twsti321
twsti321's Avatar
would gas cap fix the problem?
Old 10-15-17, 08:05 PM
MDMXLX
MDMXLX's Avatar
P0441, P0446 here. Based on this thread, I think I'll try the Purge valve.
twsti321 (10-28-17)
Old 05-13-18, 09:10 AM
YLK
YLK's Avatar
Default P0441 & P0446 on 1999 Lexus GS400
Same here...I also get...
- P0441 - Evaporative Emission Control System Incorrect Purge Flow
- P0446* [Pending] - Evaporative Emission Control System Vent Control Circuit Malfunction
My 1999 Lexus GS400 will get a new purge valve (90910-12109, vacuum switching valve).
Thanks to ALL for the thread.
BTW, I tried to contact CL via https://www.clublexus.com/contact-us/
regarding the ugly printout via Ctrl+P but get the message...
"Failed to send your message. Please try later or contact the administrator by another method."
Any improvements to Print & Contact Us features would be much appreciated.
Thanks to CL for this awesome website.
Old 08-05-18, 12:55 PM
wmj259
wmj259's Avatar
Did the purge valve solve your problem?
Old 08-05-18, 01:29 PM
mate01
mate01's Avatar
Had the same codes, found out it was the rollover valve on top of the fuel tank.
Quick Reply: Advice for P0440 P0441 P0446
