2jz ge don't wont rev 4 rpm
Hi,
I have a problem with gs300 2jz ge it doesn't want rev 4 rpm sth like starting procedure, when I press acc much more I have 6 rmp and light on check engine control but the ecu doesn't notice any error.
I checked:
fuel pomp
injection asyy
inginterCOIL ASSY, IGNITIONMETER SUB-ASSY, INTAKE AIR FLOW
THROTTLE
timing belts is ok
the cat was cut off (removed)
engine starts properly but problems start above 4 rmp
I will check cranc sposition sensor and PULLEY, CRANKSHAFT TIMINGPULLEY, CAMSHAFT TIMING vvti
ecu is ok, I have 2 psc
Do you have any sugestion what can I do more?
I checked:
fuel pomp
injection asyy
THROTTLE
timing belts is ok
lexsc492
Performance & Maintenance
13
07-12-07 09:39 AM
