Cruise Control doesn't set
I'm having problems with my 02 GS300 cruise control not setting. The cruise lights up on the cluster when I activate the cruise control but if I try to set a speed nothing happens. Thanks in advance!
I checked the fuses and they are ok. Where can I locate the vacuum actuator for the cruise control? If it was the speed sensor would that be the only thing affected?
Jyoshi,
There is no vacuum control on the 02 GS. It is all handled by the computer. I had a similar issue, which turned out to be a connection problem under the hood at the computer. I went to check voltage on one of the cruise control pins and it was loose. It has been a while and I don't know where my wiring diagrams are, but it is easy to get to the main connector where the cruise connections are under the hood.
Good Luck.
Good Luck.
Just wanted to update the solution to my problem. It turned out to be the connection that is near the throttle cable. I just unplugged it and plugged it back in and everything is working fine. Thanks for your help.
arianna
11-19-06 02:41 PM
