Questions on foglights
Old 12-23-17, 04:41 PM
AgedGS
AgedGS's Avatar
Question Questions on foglights
I have clear lenses on my foglamps, presumably factory, and they shine yellow. As of late, I've noticed one of them has turned more of an amber color than yellow.
1) Are all of the oe fog lamps on the US 2GS the same? I ask because i have seen people referring to yellow v/s clear factory ones.
2) if there is a difference, is it strictly in the bulbs, or is there something in the housing?
Old 12-23-17, 05:24 PM
mate01
mate01's Avatar
I have a 2001 GS 430 the housing is clear and the bulbs are yellow .Was thinking about switching to led.
AgedGS (12-23-17)
Old 12-23-17, 05:54 PM
AgedGS
AgedGS's Avatar
I thought about hids or leds, one, but didn't want to go that route if the discoloration was in the housing.
Old 12-23-17, 06:11 PM
mate01
mate01's Avatar
One thing you might want to do is clean the housing mine were so dirty I couldn't even hardly see the light .
AgedGS (12-24-17)
Old 12-23-17, 07:51 PM
Mr Jokster
Mr Jokster's Avatar
They're all the same, per-se, but one has a yellow capsule inside in which the bulb illuminates inside to create the lovely yellow. If you're seeing amber, I wanna say you may have HID's in there and one is going bad. Also, its possible you do have the yellow capsules and the previous owner threw HID's in the capsule with still the same going bad issue. Its just a matter of getting down you your knees and checking.
Do you have factory HID's? IIRC, Halogen GS's don't come with the yellow capsule option.
With the car off, you should be able to see the yellow capsule through the clear lense, if you don't, then most likely its a bad HID (yea I keep saying the same thing ) Heres what you should see with them off (if they're true with the capsule)
The following 2 users liked this post by Mr Jokster:
AgedGS (12-24-17), mate01 (12-23-17)
Old 12-23-17, 07:57 PM
mate01
mate01's Avatar
One thing I'd like to add will a regular phillips screwdriver remove the housing ?
AgedGS (12-24-17)
Old 12-23-17, 10:21 PM
MedicalDoc
MedicalDoc's Avatar
He's it will. A # 2 phillips.
The following 2 users liked this post by MedicalDoc:
Old 12-24-17, 03:26 AM
AgedGS
AgedGS's Avatar
Yep. That's what my fog lights look like when off. I do have factory HIDs for the low beams. Just to be clear, if I do have HIDs for the fogs too, that's not factory, correct?
Old 12-24-17, 06:22 AM
Mr Jokster
Mr Jokster's Avatar
..correct..
Old 12-24-17, 07:34 AM
English66
English66's Avatar
On all 2nd Generation GS that came with HID headlights from the factory you got Yellow capsule fog lights. If you got Non-HID headlights from the factory you got clear (no capsule) fog lights....
Old 12-24-17, 09:48 AM
AgedGS
AgedGS's Avatar
Got it! thanks guys! I'll be tearing into them this afternoon to see what's what.
Old 12-26-17, 01:46 PM
AgedGS
AgedGS's Avatar
So , I took the fog lamp off that looked discolored, and they are not aftermarket HID's. I took the bulb out and cleaned out the yellow capsule with some rubbing alcohol, to no avail. Looks like it's time to replace and maybe upgrade the bulbs. I can't imagine that one capsule would discolor & the other would stay the same.
Old 12-27-17, 06:12 AM
Mr Jokster
Mr Jokster's Avatar
Swap the bulbs. I cant see the capsules discoloring at all...
Pics?
Old 12-27-17, 08:01 AM
AgedGS
AgedGS's Avatar
Pics?
My thoughts, too. I'll get a pic up this evening after work. I'll be adjusting the headlights a bit anyway.
Old 12-27-17, 10:42 AM
sakataj
sakataj's Avatar
that glass isnt clear its fluted. they do make aftermarket fogs with clear glass now though
AgedGS (12-27-17)
Quick Reply: Questions on foglights
