Repinning ecu aristo swapped gs300 help
Old 02-07-18, 03:57 PM
  #46
grupple
grupple's Avatar
Alright thanks guys probably wont have a chance till this weekend to keep digging into the wiring. Just 2 other questions if for some reason i cant find a fault on why it wont start with the key i could run a push button start by running a hot wire from push start to the starter wire on ecu? And i literlly have just about ever dash light lit up even oil light. Im going to get oil psi gauge just to make sure i dont have low pressure but has anyone had that before
Old 07-23-18, 06:41 PM
  #47
Sonnie1234
Sonnie1234's Avatar
Default Need help
Bought a new battery, it was too tall
And cause it to catch fire.... it knocked out all the power.... fuses good and the only time it cranks up is when the obd I’m inserted and as soon as you put your foot on the brake or turn signal it cuts off
Old 07-24-18, 07:05 AM
  #48
sakataj
sakataj's Avatar
so rude man, why dont you make your OWN thread?
Old 07-24-18, 08:55 AM
  #49
Sonnie1234
Sonnie1234's Avatar
Default Idk how
idk how to make my own thread I just need help
Old 07-24-18, 08:56 AM
  #50
Sonnie1234
Sonnie1234's Avatar
Default Not trying to be rude
idk how to do that
Old 07-24-18, 10:11 AM
  #51
Letsride
Letsride's Avatar
Click on link.....
https://www.clublexus.com/forums/new...ewthread&f=184
Grandpabob
Performance
04-20-20 12:26 PM
ElitistK
Performance
03-26-19 06:56 AM
876
Performance
10-24-16 07:23 AM
wingzero
Performance
08-23-12 05:35 PM
Quick Reply: Repinning ecu aristo swapped gs300 help
