Easy Faded Inner Taillight Permanent Fix ($16)
Very important to take note is that VHT requires VERY LIGHT coats. Don't overlap on your passes and wait at least 10 minutes before applying another coat. If you apply it too heavily it will run, or crack, you can tell when it is too wet. I did about 6 coats of VHT. After that many coats the color is still translucent, but it looks Like more of a matte finish. In order to do a glossy finish I bought a gloss clear coat that is UV protectant and seals the VHT product. Now, it will never happen again. For the gloss clear coat, I waited 1 hour for the VHT to dry and then did 5 coats of the clear to ensure protection and maximum gloss effect. This is more like spray paint, overlapping passes, 8-10 minute dry time between coats.
VHT:
Clear Coat: https://www.homedepot.com/p/Rust-Ole...9117/100670438
VHT:
