Abs making a humming/buzzing noise
whats going on guys!
i got a 2000 GS300 101,400 with a ton of problems and I have been working on it for a while now. I had a code come up for “vehicle speed sensor A”. I changed both vehicle speed sensors but no luck with a scan tool clearing it my mph and odo doesn’t work. Does anyone have a diagram where the wheel speed sensor is located ? I wanna check those out. My check engine is still on but for Park/neutral safety switch and a 02. Also my ABS and VSC off is on on top of that not sure if it’s related but I’m getting a humming/buzzing noise from my abs manifold every 60 seconds. It is also leaking but can’t tell from where exactly. I don’t see anything leaking around the manifold.
Moorelow (02-27-18)
I’ll check my brake lines! I’ll jack the car up have my car step on the breaks with the car on maybe and see what’s sup. I didn’t notice any leaks coming from the manifold what so ever!
Globalinx
GX - 1st Gen (2003-2009)
03-04-14 01:17 PM
