Swap 2jz-ge vvti for 3uz-fe vvti
To find a 430 in the color combo I have local to me would be rare and probably end uop costing me $5k+. I already have alot of time into my current 300 and would just rather have the 3uz as far as power goes. Labor wont cost me a dime since i have my own shop and will be doing all the work myself, just looking for input as far as wiring goes. AZJDM has the 3uz motor/trans/ecu/harness for $950 so as far as money goes its not expensive at all
Well if you have the engine, computer, and harness available, it would swap in and run. But I wouldn't waste the time. Keep your eyes open and one will pop up one day. And it will be better off than your custom install more than likely. The 400/430 have other differences. The radiators are thicker, obviously you need the exhaust parts, the transmission in the V8's are different than the 300. Different gearing in the rear end. Probably a great deal you would run into. No swap ends up cheap. What about A/C? all the in's and outs of every system.. You'd end up with an incomplete, less than satisfying car that no one would want to buy. Just being realistic. You can get a 430 for cheaper if you wait for it.
@badblackgs did the opposite swap of a 2jz-gte into a 430 after his supercharged 3uz blew a rod. Its definitely possible but he mentions a ton of wiring that needed to be changed to make it work in his thread.
benjiSC3
Performance & Maintenance
05-09-14 08:52 AM
pass1914
09-15-05 03:35 PM
