intake induction cleaning
Old 03-19-18, 03:36 PM
silverbul
silverbul's Avatar
Default intake induction cleaning
I have this induction device I saved her I use to work at Firestone I used to clean my intake manifold. For cleaner I used seafoam.
Old 03-19-18, 03:44 PM
silverbul
silverbul's Avatar
Next I removed the black tab & connected the tube to the intake.
Old 03-19-18, 03:53 PM
silverbul
silverbul's Avatar
Next I started the car & set a brick on the accelerator to hold the rpm at 2500. The cup has a hook on it to hang on the hood latch. Poured the seafoam in the cup.
Old 03-19-18, 03:56 PM
silverbul
silverbul's Avatar
Old 03-19-18, 04:00 PM
silverbul
silverbul's Avatar
Then I slowly cracked the valve open so the seafoam can slowly drip thru the iv sight glass. Warning: you allow it to shoot thru too fast it'll make the check engine light on. So I went slow
Old 03-19-18, 04:11 PM
silverbul
silverbul's Avatar
No more smoke.
​​​​​​​Let it run until the intake sucks all the seafoam thru the intake. You will see tons of smoke coming out of the exhaust. Then I put the tab back in then & let the car run until everything went clear & smoke went away. Intake nice and clean
Old 03-20-18, 09:46 AM
fperron
fperron's Avatar
What exactly was the reason for embarking on this exercise? Were there symptoms that indicated that a cleaning was needed?
BiGEZ (03-21-18)
Old 03-20-18, 11:51 AM
BiGEZ
BiGEZ's Avatar
See the label on the can in pic # 2.
I did this years ago on my old Nissan 300ZX with good results, However I am hesitant to do it on my cars as I most likely will have to replace the O2 sensors which gets fouled up from all the smoke. I just installed 4 brand new OEM sensors and don't want to get them messed up.
I just use Lucus injector cleaner every other tank of gas to keep the fuel system clean.
Old 03-20-18, 01:58 PM
SaiyanGS3
SaiyanGS3's Avatar
Lucas doesn't work. You need something with a good amount of PEA in it
Old 03-21-18, 05:41 AM
silverbul
silverbul's Avatar
The purpose is to break up carbon that builds up from over the years. Try to keep it running like new.
ModInJapan
CL Vendor Products for GS-F
11-22-18 12:55 AM
ModInJapan
CL Vendor Products for RC-F
11-19-18 04:14 PM
Kaidan117
RC - 1st Gen (2015-present)
02-11-17 07:52 PM
mumbles
Performance
14
10-02-03 02:45 PM
Static911
Performance
58
06-25-02 09:22 PM
Quick Reply: intake induction cleaning
