How low without alignment problems
I'm planning to install Megan EZ coilovers and wonder if anyone knows how low I can go and still maintain factory toe. I can tolerate up to -1.5 degrees camber, so I'm not worried about that. I just don't want to have to mess with aftermarket toe kits. Thanks.
fperron (03-20-18)
Alignment shouldn’t be a problem at all with stock parts once you’re not too low, on 19 or 20 you can sit on the top of the tire and be able to stay within specs , but just to be safe , it would be good to get a toe arm in the back , that really helps a lot , other than that you’ll be fine as long as you not trying to tuck tire and rim
The lower you go, the more camber you'll end up with. Mine is down about 2" on H&R coilovers, and with the OE camber adjusters set as positive as I can make them, I still have -2.3° camber front & rear. I could correct this further with aftermarket arms but I don't drive the car enough to justify it.
A 1.25"-1.50" drop is about as low as you can go without ending up with more than -1.5° of camber. When I first installed my H&R coilovers it was lowered 1.6" and ended up with -1.75° of camber with the OE adjusters maxed-out positive.
Another thing to consider is wheel fitment - with an aggressive wheel/tire set-up like mine, the tires would rub if I reduced the camber at all.
It's interesting that most responders seem to think that camber is the main issue. Actually, toe is much more critical to tire wear. That's why I initially stated that I could live with -1.5 camber, but need to keep toe close to zero.
fperron (03-22-18)
Never had a problem getting toe back within spec, so probably why I didn't bring it up. You're right though, you can't really change one spec without having an affect on the other. Most guys even-out the camber first and then set the toe.
