2001GS300 over 250k miles VSC light is on? went off for a few weeks [installed new denzo spark plugs. lights were off [prob after resetting computer they stayed off 3weeks. Now vsc lights are back on any suggestions?
If it's just the VSC lights. Check the ABS speed sensors. One might be completely dead, and not sending signal. If you have a ABS scan tool it'll let you check which one is bad. If not you can disconnect it, and check it for resistance with an DMM.
With certain engine codes and the check engine light on, it can disable the vsc system and cause the light to stay on. My friend had a bad oil vvti solenoid and that caused the vsc light to come on with just that one engine code on a IS300.
