Rim and tire size
Rim and tire size
I have a 2002 gs300 right now everything is stock. I want to lower it a little bit and put 18s on. What size wheels and tires would fit best?
Mr Jokster (03-24-18)
The gap would be filled by it being lowered are you saying the tire should be wider? What offset of rims would you suggest?
Heres your best bet:
http://www.rimtuck.com/search/thumbnails&make=Lexus&model=GS&yearfrom=1998&yearto=2005&sort=1
Too many threads about wheels, its best to search both here on CL and the above link. Rimtuck is your best bet because it has all the offsets and fitments WITH pictures. Check out each pic and find what you like.
Also look at the other size wheels like the 19s and 20s, the offsets will look the same, just not the large diameter .
As for the gap, I'm talking about the horizontal gap, not the vertical gap.
In my opinion, most styles in 18's look funny on a gs300.... I had 18 before on air and I didnt like it. I went 19 and it filled the wheel well a little better. Now I want to get 20, but nothing bigger than 20. You have to do a lot of thinking when putting on wheels. Take your time and dont rush it just cause you want wheels. Know what you want before buying.
