Parts for timing belt service
Hi all,
I have to replace my timing belt soon and I'm wondering which parts I need to replace together with the timing belt, waterpump etc. I've seen a kit on eBay which contains some OEM parts for the timing belt service (https://www.ebay.com/itm/NEW-LEXUS-I...s=Make%3ALexus)
This kit contains the following parts:
* Timing belt (Mitsoboshi)
* Idler (Koyo/NSK)
* Hydraulic tensioner (Toyota)
* Drive belt (Bando)
* Front cam seals (Toyota)
* Front crank seal (Toyota)
* Water pump (Aisin/Asco)
* O ring (Aisin/Asco)
* Thermostat (Toyota)
* Thermostat gasket (Toyota)
* Oil filter (Toyota)
* Drain gasket plug (Toyota)
Are these all the parts that I'll need for the timing belt replacement? I want to replace the spark plugs and V belt too. Mitsoboshi, Koyo/NSK, Bando and Aisin/Asco are all OEM brands right?
Thank you!
Kind regards,
GS300freak
* Idler (Koyo/NSK)
Thank you!
Kind regards,
GS300freak
That kit looks fine assuming you are going to do the work yourself. However, if you plan to have a shop do the work, check with them before ordering the parts. Many shops are (understandably) hesitant to let customers provide the parts for jobs like this. That's because they know what parts to order and don't have to post on this forum to get it right. They also have contractual relationships with certain vendors and that makes it easier to deal with situations where the vendor ships wrong or defective parts. Also, the shop is giving away money when they let you bring the parts.
It really depends on the shop you choose to do business with. Of course you're correct if we're talking about a Lexus stealership, but there are plenty of honest shops out there who are more interested in developing a loyal clientele than in burning people on a one time only basis. For example, if you live in west Florida, check out Gulf Auto Clinic in Bradenton.
Just as an example. My previous indy charged no labor for an oil change. He got his parts from NAPA. You could go with whatever he chose to put in or choose the brand of oil/filter you wanted, as long as he got it. He would charge you whatever NAPA would have charged you if you bought it at the store. The profit for him? NAPA's charge to him was half of whatever the cost was to the public!
Sometimes I read that people preventively replace the head gasket when changing a timing belt. Do you guys think this is necessary for the GS300? I don't have any oil/coolant leaks or something...
Yeah, you missing some gaskets in this work.
- valve cover gaskets (intake and exhaust, they are different)
- throttle body or intake manifold dual-pipe side gasket (this must be removed to get access)
also I suggest you to change PCV valve in the intake valve cover and spark plug wires
more likely, you will need connectors for the coils to be replaced on the wiring harness. After a few years, they are very fragile.
It will crack in pieces in the hands of your mechanic.
lserlohn
RX - 1st Gen (1999-2003)
07-07-15 03:43 PM
VHTx2011
09-12-11 08:38 PM
