Hi everybody guy at work is offering me a deal on some rims he say's he has. Would this offset be to aggressive for a DD I dive 85 miles a day. I have no problem with rolling/pulling fenders but not trying to bacon my fenders Lol. Thanks in advance for the help.
RPF1 18x9.5 +15 all around tires are 245-45
There is no way that will fit in the front without some serious work. 18x9+38 front would be the most that you could fit without rolling from what I've seen. That sounds like they're off an STI or Evo
Thanks I appreciate the quick reply, might be going this route now
18x8.5
18x9.5 plus 35 for both
I run 18x9.5 all around with 255/40 tires. No my car is not stanced, it is actually for track use. No wide body, no fender flares. all stock body panel.
What offset are you running? I was thinking of running a staggered wheel setup for daily use but I think I wanna run 9.5 all around instead so I can rotate the tires...
I have 18x9 +20 with no fender work at all.
I agree that 9.5 +15 with a 245/45 won't fit nicely. That's a chunky tire, especially for the front.
Do you have a picture and what are your camber settings? I'm running 18x8+40 with 245/40 front tires and it looks close to rubbing but if I can fit more tire I want to. I know I need another set of wheels though
I lost my specs on my phone. But this is a rough run down. This is with 245/35/18 but federals runs a little wider than the size printed.
-2.5-3 front camber
-2.0-2.5 rear camber
+22 off-set, warning, if you run what i do, you might run into the tire rubbing on the backside of the wheel well during hard turns.
