Door locked shut
Door locked shut
I just changed accuator in my door due to locking and unlocking problems and now the door is locked shut. I can hear it unlocking and locking with the remote and from inside door switch, but it wont budge.
can anyone please help me and let me know if theres a trick or something
thanks in advance
thanks in advance
When you replaced the actuator did you snap the ball back in place. If not the actuator isn't moving your lock. Also this is a valuable lesson to not put everything back together until you test it when you can. If it is in fact locked shut though, you're going to have to cut a hole in your door panel if you already put that back on and closed the door.
The door panel is not back on, i didnt want to put it all back together, find out something didnt work, and have to pull it all apart again.
so the door is shut and i can fiddle with the accuator from the inside, i can remove the outside door handle and look in from there also.
I did manage to push down the 2 rods that connect to the ouside door handle, and the door popped open. I have since shut the door and it is locked shut again
Lubeboy
SC- 1st Gen (1992-2000)
05-30-17 12:52 AM
tonyzebra
15
08-22-12 04:40 PM
