The offsets were quite close to the GS's, that's why they were so sunk without the spacers.
245/45 is taller than OEM by two inches, more than an inch and a half over what you have now.
ok, so to be closest to stock i should go with 235/35? i would like some meat on the tires just cause i dont wanna hear too much road noise, would anything be ok with 40/45?
You have 19" wheels and your car is very low. That's the reality of having larger diameter wheels. If you want bigger sidewalls you have to either get smaller wheels or have tires that are larger than recommended for the car.
Thanks!!! im going to grab some 245/35 for the fronts and when the rears go ill probably make them all 245/35
