DIY - Antenna (aerial) manual extend/retract override switch
If you have ever wanted a way to manually retract your radio antenna, this is the guide for you! I will show you where to intercept the signal wire going to the antenna control unit and install an in-line rocker switch to manually control when it is extended. The main reason I had for wanting this was due to the fact I utilize the AUX jack which I have spliced into the factory head unit ( see this guide here ), more than the radio, but due to the nature of that mod it would leave the aerial extended when not in use. Since performing this I have also found the radio will still work fine with the antenna retracted for the most part (provided you aren’t too far away from the transmitter source) which is a nice bonus
Tools + materials required
- 2 pole Rocker switch
- Wire
- Crimp terminals
- Crimp tool
- Side cutters
- 10mm socket
Approximate install time is about an hour (if that), a very simple beginner level mod
Firstly, remove your factory head unit ( see this guide here )
Once you have it out of the way, located this plug on the harness, this goes directly to the antenna control unit in the trunk. You need to snip the Black+White wire with enough length on either side to add crimp terminals
As a test you can mock up the rocker switch directly inline and test the extend/retract function. Take note of which way is up/down as you will need to remember when you install the switch in its final location
Once you have tested, you can go ahead and crimp up some wires coming from the harness long enough to reach the desired location of your rocker switch
I chose this spot next to my headlight washer button as there was already an accessory blanking plate with a hole through it from an old handsfree phone kit install. I printed out the antenna logo sticker with a vinyl cutter for added OEM feel
- Wire
- Crimp terminals
- Crimp tool
- Side cutters
- 10mm socket
Op, does it still raise up automatically when turning the radio on? It would be ideal if it'd raise up and after that I could hide it manually if I want to.
Edit: ..and also, great tutorial once again!
vicSC400
10-08-21 09:52 AM
Arthurt
10-27-11 09:00 AM
zdatlexus
02-16-10 04:20 PM
