Lexus GS300 Crystal white pearl 062 paint.
I need to paint fender on my lexus. My color of my lexus is crystal white pearl 062. I want to paint it my self. This paint is kind of expensive. I found a crystal white pearl paint on ebay with code 62 for 2014 Toyota camry for $32.98 12oz aerosol can with free shipping. Will this paint match my lexus. It says that the paint is crystal white pearl but the only difference is the color code. My color of my lexus is 062 but the camry is 62. Here is the link for the the crystal white pearl for camry https://www.ebay.com/itm/2014-Toyota...4AAOSwRgJXiZjx
I'd be a little wary about this if you're going for a perfect match as the 062 paint code for our Lexus is a tri coat, this is just a single can. To be able to match the paint properly on your fender you'd use a base coat, the mid coat and a clear. Which means it will be a little more expensive as you're buying three spray cans versus one.
Yeah, had this experience with my diamond white pearl. Definitely had to do all three separate coats to get it right. I wound up finding out what the base color was for mine, which was a different lexus white, 042 I believe, then had my local automotive paint company custom make the pearl coat, and then clear coated it. I tried other kits from online and they were not close at ALL.
