Sideskirts that do not "lower" the car?
Hi guys,
Do any of you know of a set of sideskirts that does not reduce the ground clearance or at least not too much?
When I had my L-Tuned shocks and springs, the L-Tuned sides were OK. I only ran into problems with extreme speed bumps. Now that I am lowered more (via Flex), I am finding places that I clear before and not any longer. The TTE lip is still OK but that down-swoop at the end of of the L-Tuned sides have given me problems a few times. I avoid those areas now but am searching for a better solution.
I went away from the stock sides since I did not like the 2-piece design. I thought that middle line detracted from the lines of the car. What I am looking for is a one piece side-skirt that will lower the car only an inch or so. I have about 41/4" at the front with the TTE lip while only 3" at the ends of the L-Tuned sides. I have about 5 1/4" at the middle of the sideskirts, which I think is about stock height. I'd like something in between, maybe straight across. I figure if my lip clears, my sides should too.
Does such a beast exist? Thanks for any info.
Lexis11
02-22-07 05:43 AM
