Cool "hidden" features about the GS that are not very known
#421
4. In the glove box, you can get to the Air conditioner filter and clean it out. You can remove the panel by pulling it straight out and than slide out the A/C filter. I could not believe how dirty and filthy my filter was and I was breathing all that ****** when the AC was on.
http://members.bbnow.net/txalec/
#422
wiper stops
My wipers were in summer mode for the longest time until some ******* at my apartment set them in summer mode for me. I walked outside one day and my wipers were visibly in winter mode. Wtf! I've tried to set them into summer mode twice now but I've never heard the "POP" when you reach the final position. The wipers seem to get in the way of themselves when I'm pulling down. I end up having to lift up on the wipers off the glass 3 or 4 inches so the arms and blades don't hit each other and I swear I am pulling wayyy below the window. I guess I need to pull them down to where the drain grill is??? I want to hear that pop baby!!
Seriously tonight I am going to walk out to my car open the hood and rip the suckers down until I hear a loud Pop. Unless anyone says thats a bad idea lol
I noticed on one user submitted picture you could still see part of his wiper blade when he asked "Am I in summer mode?" I don't believe this is correct. It is my personal believe that these wipers in the picture are *not* fully in Summer Mode.
(picture from post#139)
BTW I have an '01 GS430..
I like a lot of people just read this fun thread. @ work! Most of you guys still have a factory radio? I have a really nice setup with Focals, 2 amps and 2 10" subs. I kinda wanna get horntones too but that might be too much and kinda gay.
I have a python alarm that was installed with remote starter the doors lock when I start the car and unlock when I take the key out. I'm not sure if that is because of the alarm though.
I also have no seatbelt beep. I bought the car used and it was already modded to hell with a 2800rpm torque converter, sway bars, and all my lights including my reverse lights are blue!
Thanx guyz Absolutely love all the tips
#423
1. It's in summer mode, because if it's in winter mode, the wiper comes up and you can see them in the cabin.
1.5 I've noticed though sometimes after you turn the wiper off, it will retain a little bit higher than the summer mode....
2. Doors locking and unlocking when you start/turn off the car is from the alarm, it's programmed to do that, but not from factory, just like my old car's Compustar 2 way alarm with remote starter.
3. "modded to hell" what mods you've got?
4. I have factory Navi, it's just a pain to change to after market like my old alpine set up in my old car thus I left it alone, it's not like I need a system in my GS as it's so quiet that I just use about 1/4 of the volume.
5. 2 10" subs... so you've got 3 then? as there's a OEM one in the rear deck you could use, I just slapped a Kicker Comp free air in there and it's enough for me though...
6. Don't pull the wiper down to the drain, try pulling to winter mode again and pushing them back to summer to see if you get the pop, if not, theres' something wrong, does the wipers themselves work in the winter mode? see if it's out of alignment.
7. Welcome to the club.
A picture for reference, mine also sticks out a bit higher than the hood edge, and I have those thin flex rubber blades, thus you'll see less of the blade.....
it all depends on the angle/height you shot the picture at.
#425
if you really need to get it opened without getting it fixed, you'd probably have to crawl into the back seat, get the door panel off or at least partially removed, and pull the latch actuator cable to undo the latch. Good luck getting a door panel off a closed door, it'd be much easier to just get it fixed.
#426
not really a hidden "trick" but try taking the child safety lock off. it doesnt let u open it from the inside. i thought the door was broken once when i realized someone accidently hit the child lock on the side of the door
#427
My brothers Mazda MPV had the same problem a few months back. We first got a new(er) inner door panel from the junk yard, then I used a dremmel with a cut-off tool to cut a big hole through the stuck door panel to gain access to the locking mechanisms. In his van, the problem was that the actuator got jammed. Had to use some brute force to free it up. Then we replaced the actuator also. Apparently this is a common problem with the last generation of Mazda MPV's
Not sure if this helps you in any way...
#428
The seatbelts tighten up if the steering wheel is turned past a certain %, and I hate it! On the premium sound system (not ML), the set button on the steering wheel can be set at different levels to make a mute button, or where ever you desire to set the volume. Just set the volume to desired level, and press and hold "set".
#430
Drew,
Thanks for this hidden feature. I thought only the Mercedes-Benz has this kind of feature. I had tried #2 and it works great. I'm going to play with the rest of the features later. Keep us inform if you happen to find any more
hidden secrets that you would like us to know.
Thanks
Thanks
#431
#433
I don't remember if this have been posted...
One time, my car had a flat, it seemed fine when I park it, but the next morning when I started up, and released the handbrake, the handbrake light kept on, I then looked outside, my right rear tire's very low. Shut the car, pumped the tire back up, the light's gone.
#434
Help
Hi,
I'm installing the alarm/remote starter into my GS430. The problem I'm having is every time I unlock the door, my steering wheel move in/out. Is there a way to stop the AUTO tilt function? According to the C-BEST setting(Tilt & Telescope AUTO TILT AWAY ON ON/OFF of auto
away/return function) what it is mean? Please help.
thanks
thanks
#435
Hi,
thanks
thanks
