Locked key in trunk
Old 08-18-18, 11:14 AM
Crisjonson
Crisjonson's Avatar
Default Locked key in trunk
Doors open by locksmith on 2004 gs300, alarm went off when doors were opened, how do I get into trunk
Old 08-18-18, 11:45 AM
Mr Jokster
Mr Jokster's Avatar
If the door is opened... Why not just pull the lever to open it
Old 08-18-18, 12:49 PM
firelizard
firelizard's Avatar
Maybe they've locked the trunk.
If that's the case, the back seat needs to come out and you need to remove the trunk liner from the inside, crawl in and use the trunk release lever.
Old 08-18-18, 02:45 PM
2gz
2gz's Avatar
You could use your tools and take apart the lever that opens the trunk. There is a small pin behind the spot where the key goes, you just push that in and it will unlock the trunk lever.
Old 08-27-18, 07:51 PM
TW99GS300
TW99GS300's Avatar
When the alarm is triggered the lever switch is disabled. You would need to disable the alarm first by turning the lock barrel on the door, (or simulate the unlock of the door somehow). If the valet lock switch is pressed in then you need to release that lock switch next.
BigGoober
09-04-12 03:17 PM
jiggahwh0
SC- 1st Gen (1992-2000)
09-26-10 08:06 AM
BIGBADDAD
30
05-18-08 07:18 PM
kolofai
01-30-07 08:39 AM
Quick Reply: Locked key in trunk
