Steering Tilt/Slide Mechanism
My steering tilt/slide mechanism has developed a fault.
It will tilt manually and upon removing the key however the (slide) telescope action has seized. It will move a small amount so I assume the motor is working but maybe the mechanism needs greasing.
Any advice appreciated including what need to be dismantled to get to the area.
you can try searching in the advanced search function. There are older posts with the same issue.
