VSC, ABS, VSC OFF, and Break Lights on Sporadically
I have a 2002 GS300. I just did ball joints, inner and outer tie rods. After I was done the VSC, ABS, VSC OFF were on constant. A few days later the went off but now come on sporadically with the break light and my speedometer wont work. If I shut the car off and restart they go away. They come on most often when the car is cold or idling. Is it possibly the speed sensor? Thoughts?
I check my battery voltage, and it was low, and this new battery. Than I check the alternator, was low voltage also.
So I went ahead to advance auto part to buy new alternator, and I replace it. That was the cured of the problem.
vsc, abs, vsc off light never come back on, and it has been more than a year now.
