Fastest gs300/aristo
hey guys ive been trying to find the fastest street legal gs300/aristo and I know about that 7 Sec monster... I know in the states you have crazy laws and things like that can be street legal but I’m talking street car. Full interior,AC, full sound system. The fastest I can find in Australia is a 10.4 1/4 mile, I’m assuming the states have something that has gone faster. With what I have done to mine I’m looking at high 9 low 10’s no problem . So just wonting to see what’s out there and what I need to beat to have the fastest street legal gs300. We did a few dyno runs and the car put out 380RWKW on 98 octane, I think that’s 91 in the states and on 21psi. We never got to use e85 or 30psi coz my brand spanking new turbo failed after 16 dyno pulls. I’m not gunna name the brand as I’m in the middle of working out a deal with them and finding out what the problem was for it to fail so soon but if the blame me or my engine builder I’ll let everyone know. Its brand new engine build. So it wasn’t anything in the oil and it had a pod filter so nothing got sucked in and you can’t over speed the turbo on 21psi.. we are 3x over speeding another turbo for the last 2 years with no problem.
There's a sticky thread in the Performance section with 1/4 times.
Top 10 1/4 Mile Times
Seemed to be active up to 2017. You might be able to revive it when you get your turbo situation sorted and get some runs in. Would be interested to see your build and what you're running, you should start a build thread with your swap.
Cheers.
Cheers.
2JZ only? Based on what the car weighs, and how much power a 2JZ can make, the quickest you could hope for is 9s (as a street car). There's no way you're doing that with a full interior plus ICE though. You could probably go tens, that's within reach.
You can see this guy run 10.2 at 137 in the sort of build you're talking about. It seems they're aware of the 1/4 mile time thread here, so they're likely a member.
"Stock long block / Titan VVTI 264 cams, Motec M800 ECU, 6766 Turbo with 1200 cc injectors. Darin at DD Tuning is building the motor with some H beam rods and 10:1 pistons." and for trans "Sound Performances SP400 / Gear Vendors O.D"
In theory, 9s are possible with a fully built motor, but the car needs to start losing weight and making more power; every tenth you try to shave off is harder than the last.
That would be if you're going for quickest. I don't know what fastest trap speed is.
Cheers.
Cheers.
https://www.youtube.com/watch?v=Z3IUoDzBEGU
firelizard (12-21-18)
Any plans for the rearend? Be impressive to see 1000whp @ 30psi with a stock long block. Definitely going to follow your build and see how you do. Awesome to see someone trying to push the limits of the car don’t be too reckless though haha don’t forget a transmission blanket if you’re willing to grenade one.
GreekPower
05-25-16 07:00 AM
