Spent 2 days trying to debug no-start 1999 GS300
I bought the car two weeks ago, it was running fine.
I go to start it a few days ago with a full battery and there are the following symptoms
To diagnose I tried
1. no starter relay click
2. multimeter reads 12.4v
3. checked AM2 fuse
4. car security light is not flashing
5. transmission is in park, the dash says "P" for Park
6. with the key turned all the way to the right, i removed the starter relay from the fuse box and tried to over-ride the starter relay using a jump-wire from posts 1 and 2 - didn't work
I rode my bicycle to the nearest mechanic, andI asked him to visit the house for a diagnosis ($50)
We spent about 30 minutes on it until ..
1. He used a jump wire to cross posts 1 and 2
2. He hit the starter a few times with a hammer, the car started!
He told me the ignition is not sending power to the starter relay, that's why it doesn't click
He also told me the starter is not working, and i'll have to replace that too
I thought it was strange that he said the starter motor and the ignition are gone at the same time
When I got home, I tried to reproduce the fix (jump wire and hitting the starter motor), and I couldn't get the car to start, I tried it for hours
Please help me to get my car started again
Starting Circuit Diagram
https://www.clublexus.com/forums/att...ng-circuit.pdf
Picture of starter relay
https://www.clublexus.com/forums/att...n-dsc_0229.jpg
Where to whack the starter
Fix 1:
I found the 5a starter fuse in the drivers footwell was blown, I replaced it, but the behaviour hasn't changed at all - the car still doesn't start
Update
Still no lack with the fuse or whacking the starter
To diagnose I tried
3. checked AM2 fuse
Fix 1:
Update
Last edited by Mattkz; 01-10-19 at 12:02 AM. Reason: Fixed Problem, Updating Title
Guys I fixed the problem
Problem 1
1. The mechanic said "it's not a fuse" so I ignored the fuse box in the drivers footwell (RHD GS300)
2. The 5A starter fuse was actually blown, so the ignition key wouldn't turn the car
Problem 2
1. I was jumpwiring starter relay poles "1" and "2" instead of "3" and "5" so it kept blowing the 5A starter fuse
Fix 1
I jump wired the correct terminals "3" and "5" and the car started
Fix 2
I replaced the starter fuse inside the car, and the car would start completely from the ignition key
This could have been resolved much sooner if I had known how to properly read a relay diagram and if I had first checked all the fuses on the wiring diagram
FYI a paperclip works fine, see this awesome video ..
Problem 1
Problem 2
Fix 1
Fix 2
OBD2 scanner
I was about to buy a bluetooth OBD2 scanner to assist with the debug further
Would it have shown the solution a little quicker? Eg. "Interior Starter Fuse not Working"
To diagnose I tried
3. checked AM2 fuse
https://www.youtube.com/watch?v=O_Mz3RGygmg
Fix 1:
Update
To diagnose I tried
3. checked AM2 fuse
Fix 1:
Update
my Lexus es300 2003 just out of no where try turning the key it don’t click or turn over all the dash lights work batter is new when I’m under the hood and I have someone turn the key I can hear the click from the starter relay not sure if it’s the starter I work mostly on domestic cars and I’m use to hearing a click or something…. Any help will be helpful
dkillrstr
09-01-14 08:24 PM
pandulce
Performance & Maintenance
01-03-09 08:33 PM
