Steering Wheel Never Stays Centers & Bumpsteer
My 99 GS3 steering wheel never stays centered . I done changed every front suspension part except sway bar , I changed rack bushing , LCA 1 & 2 , UCA , endlinks , ball joint , tires all that and got an alignment , the problem is sometimes the steering is centered and I might turn a corner or just keep driving next thing I notice steering off to the right or off to the left , never stays center but pretty much track straight until about 70mph is where I start noticing bump steer when going over bumps or anything uneven , kinda feel like the tires are bouncy . I am running 18x8 with 225/45 OEM Lexus wheels in the front and fender is sitting right at the top of the tire .. Coulda RCA help me with this ? Or any suggestions ?
Are you trying to self diagnose or the suspension shop has done examination?
Reason I say that is the lift that the suspension shop has can configure loaded/unloaded situations and those guys can easily stress the joints with levers. At home I could not do much other than look for play min the steering link.
I just recently removed the Lower control arm and now waiting to get the alignment. I plan to go to a speed shop for alignment and not one of the speedy chain. Will cost ne 2x.
Salim
Salim
Salim
Salim
Have you checked the tensioner on the steering rack?
https://www.clublexus.com/forums/gs-...djustment.html
I just changed UCA last February with Megan UCA . I was thinking maybe the rack , but it doesn’t leak or anything , I installed steering rack bushing last February also . You think it could cause the play like that though ?
BoostAddct
Suspension and Brakes
17
10-28-11 09:29 PM
