Homelink & Sunglass Holder
Old 08-04-03, 04:44 PM
wilassasin
wilassasin's Avatar
I actually like where it is originally located from the factory........
Old 08-04-03, 04:58 PM
Neo
The One
Neo's Avatar
But this way, you also get a sunglass holder (if you want one).
Old 08-04-03, 07:51 PM
Alewifebp
Alewifebp's Avatar
Very clean job. Like others have said, looks OEM. And I believe you when you say it was tedious. I can only imagine...
Old 08-04-03, 09:24 PM
GJSGS4
GJSGS4's Avatar
I'll post a DIY soon. I got lucky and found a home link bezel (part that covers/surrounds buttons) on ebay. The new console with sunglass holder is from Steve G. Whole job cost $110 and took about 2 hours.
Old 08-05-03, 07:55 AM
SUPRATRD
Original CL Sponsor since 1999
SUPRATRD's Avatar
Wow, that is very clean
great job!
If only Lexus would learn some things from CL..................
Old 08-05-03, 10:10 AM
LS4fun
LS4fun's Avatar
Awesome job...is that a radar detector i see ?
Old 10-08-03, 11:47 AM
Blanco
Blanco's Avatar
Exclamation
So how about it?? I'm DYING to do this to my GS!!! I'm so sick of having my shades clipped to my sunvisor!!!
Please share with us your method.
PS, Steve could you get us the bezel for the buttons? Would the IS300 button set work??
BTW, your's looks FABULOUS!!!!
Old 10-08-03, 12:07 PM
Letsride
Letsride's Avatar
Arrow
Is the homelink unit self contained ie; does it just have power and ground wires coming off the buttons?
Old 10-08-03, 01:08 PM
rkytop_bob
rkytop_bob's Avatar
Look's great. You have a real talent.
Old 10-08-03, 01:56 PM
rominl
exclusive matchup
rominl's Avatar
it's wired, not self powered
Old 10-08-03, 03:11 PM
Richie
Richie's Avatar
Very cool conversion!!!
Old 10-08-03, 06:19 PM
GJSGS4
GJSGS4's Avatar
Default DIY
I found the homelink with button surround on ebay for $25. I got the sunglass holder from Steve G for around $100.
Quick DIY steps with pictures below.
1. Remove visor from car by pulling plastic cover from around visor shaft and removing the two screws. Unplug the wiring harness and take the visor to a clean work surface.
2. Using a small flat blade screwdriver remove the lens from the vanity light. Remove the two screws and pivot the vanity unit out of the visor. Disconnect the wires and remove the vanity unit.
3. Position the homelink unit in the opening where you removed the vanity unit. Trace the outline of the homelink on to the visor core (Styrofoam).
4. Using a utility/razor knife score the outline of the homelink to about half way through the Styrofoam. Careful not to cut through to the other side and destroy the visor. Using a dull flat blade screw driver pick away at the Styrofoam until you have a pocket for the home link to sit in. You will need to remove the entire depth of the Styrofoam.
5. Set the home link in the place and locate the location of the buttons through the fabric on the face of the visor. Using the button cover as a pattern cutout an oval hole in the fabric slightly smaller than the button cover.
6. Splice the two wires from the homelink into the two wires to the visor light.
7. Replace the vanity unit and snap the button cover on.
8. Install visor back in car.
9. The installation of the sunglass holder is very straight forward. Just remove the light lens, remove the screws, and unplug the wiring harness. The sunglass console comes complete with all the buttons and lights. Just plug it in and replace screws and light lens.
Old 10-08-03, 06:20 PM
GJSGS4
GJSGS4's Avatar
Default DIY PIC 1
Old 10-08-03, 06:22 PM
GJSGS4
GJSGS4's Avatar
Default DIY PIC #2
Old 10-08-03, 06:23 PM
GJSGS4
GJSGS4's Avatar
Default DIY PIC #3
Quick Reply: Homelink & Sunglass Holder
