top of motor is leaking ....
[QUOTE=BiGEZ;10460767]There are some seals in the valve cover the goes around the spark plugs, these get hardened over time due to heat and cause oil to leak into you spark plug wells.
Part number for the Toyota seals are: 11193-70010, you will need 8 of these.
Be sure to clean as much of the oil out of the wells before you remove the plugs.[/QUOTE
once i clean out everything and install the new spark plugs and the spark plug seals would i need new coils also ??
hmm that would make sense but how am i getting oil in my spark plugs ? i pulled the coil off and it was drenched in oil which is why my crank sensor went bad since i was having to much electricity running into the spark plugs , i mean thats what my mechanic said . once i change my spark plugs and get the oil out of there my car should start so ima start there and see whats going on once i clean the motor . but i will be checking where is my power steering pump leaking from also . Again i appreciate all the help and input your giving me brother .
That sounds to be the outer seal (on the edge), and the inner seal (around the plugs), and any other seal, such as something such as a pcv, valve, etc.
At this age, oil seals and suspension bushings are the first to go....
As per others, sounds that you should replace all seals on the valve covers... do remember, these cars are approaching 20yrs in age...!
Change the valve cover gasket along with the spark plug seals and that'll solve your oil leak. I recently did mine. If you know what you doing you can have it done in a few hours
will do so , i looked a youtube vid and it doesnt seem hard i just need the correct tools and all but deff going to do so cause i need my car running and with no problems .
CaptnAl
11-10-14 09:16 AM
