Factory amp bypass harness
Has anyone found a factory amp bypass harness for the M.L. system with navigation?
Thanks for the help.
2005 gs300
2005 gs300
Can you clarify what your objective is?
If you have the ML system and want to use an aftermarket amplifier, use a line output converter to send signal from head unit or factory amplifier's output leads to the new amplifier's inputs. I recommend using the signal from the factory amplifier as it also processes the signal for audio quality.
LV05gs300 (04-22-19)
lexusscturbo
15
09-29-08 10:17 AM
