know the noise? please help & thank you
Old 05-03-19, 06:20 PM
JPrince
JPrince's Avatar
Default know the noise? please help & thank you
can anybody help me figure out what this noise?
what i needed to do/have done recently. - (the noise happened before and still continued after installation/maintenance. ) one mechanic thought it was my idle pulley... it wasn't.
timing belt, water pump, auto tensioner, serpentine tensioner, serpentine belt, idler 1 and 2, radiator flush. some of this was this was just due and figured i would replace some additional parts along the way.
my initial thought was this sound was from my power steering? what i have done thus far is clean the reservoir tank for p/s fluid thinking that maybe the filters were dirty and clogged. but the noise still happens. is it tranny (drives and shift great, fluid is awesome too) ?
is it power steering - should i do a flush? (one was done about 15k miles ago)
i mainly hear it once i put it in gear and am not moving. no noise when starting car in and left in park. the sound i am referring too happens at 12 seconds. any help would be greatly appreciated.
link to the noise
(the sound i am referring too happens at 12 seconds) its like a low whine or rubbing or something.
https://drive.google.com/open?id=1BT...od-f1Zr71eonen
99 Lexus gs400
Old 05-03-19, 07:09 PM
sbagdon
sbagdon's Avatar
Can you give us any less to work with...?!
As it appears the idle changes when the noise occurs (correct...?), guessing a/c compressor, or alternator.
If it's also when you put it right in to gear, might also be a pump inside the trans.
Old 05-03-19, 07:52 PM
Alphaman19
Alphaman19's Avatar
my initial thought was this sound was from my power steering? what i have done thus far is clean the reservoir tank for p/s fluid thinking that maybe teh filters were dirty and clogged. but the noise still happens. is it tranny (drives and shift great, fluid is awesome too) ?
link to the noise
99 Lexus gs400
Twinning!
Old 05-03-19, 09:01 PM
JPrince
JPrince's Avatar
Thanks for your reply Sorry I'm not sure what other info I could provide. In the video the car is in park around 12 seconds I put it into drive while applying the brakes and there's a low drive noise like a belt or a pump I can't figure out where. it's coming from. No nose changes when I change a/c settings. So I don't think that's it and I rarely have the AC on + been way too cold for that)
What else should I try to include to try and help diagnose?
What pump in the transmission are you referring to? Thanks again for the help. Nice pic 😀 love the rims
stillman
RX - 1st Gen (1999-2003)
04-01-18 09:31 AM
Mtdave2
23
08-17-14 11:44 AM
LS400BOY
Maintenance
01-07-11 09:02 PM
klvaleri
GS - 1st Gen (1993-1997)
07-22-10 04:21 AM
Itsumo
05-20-08 08:50 AM
Quick Reply: know the noise? please help & thank you
