Bad ecu tell me what you think?
Yes, make sure the pump is grounded, and if it is then try the 12v fuel pump mod to bypass the fuel pump control module. Use the article on the Supra, our cars are similar, I did it on mine. http://mkiv.com/techarticles/12v_mod/12v_mod.htm
98 gs300 car turns over starts for a couple seconds then sputters and dies. I checked for spark which seems normal all the way until car dies. As far as fuel I can not hear pump prime or power up at all. Have 12 volts at the the pump if I jump a ground to the blue with white stripe wire on fuel pump car starts up and idles 1000rpm. With car running engine temp not registering on dash, no outside temp on air controls, ac comp clutch won't engage if I turn ac on, engine fans won't kick on at all and no throttle tps sits at 14.9% until I floor it and I get the engine to rev up only in wot. No check engine light is on the dash and all fuses and relays appear fine. Suggestions?
