Gs300 Aristo 2jz gte VVTi swap
Hey guys, I just recently purchased a gs300 and a aristo 2jz. I’m going to start the swap at next month and it’s seems like the swap is mostly a plug and play? Is there anything you guys can advice me on.
This swap is possibly one of the most performed swaps in the world. There is so much information available out there. Did you get the ECU and harness? You will need an exhaust adapter or custom made down pipe. And either an OEM inercooler setup or aftermarket front mount kit and an intake for the new air intake location at the turbo. You will need to upgrade your fuel pump. Lots of basics to keep you busy and make the swap more $$ than you thought.
Thank you truegs300. I have been looking at some info about it and I’m getting the FMIC kit, a single piece drive shaft, a MAF sensor Because it did not come with my 2jz, also a fuel system, and a throttle cable and the exhaust system as of right now. Do you know which exhaust kit sound good? Nothing too loud.
