Lexus Gs400 remote turn on wire
Old 06-11-19, 09:24 PM
iGotDat1UZ
iGotDat1UZ's Avatar
Originally Posted by brains646
I've used the JBL speakers in the past for budget systems due to their high input sensitivity. Coupled with the mini amp and a solid mount they really sound great. I had this setup in a 2008 Ram with only stock replacements and I never missed a sub. It's been a while since I looked into aftermarket speakers so I'll definitely look into crescendo when I start tho. So far this is what I've done
That headunit is a clean install. Good work! I will show this thread my subwoofer build when it is done. Right now I have a skar audio sdr12 with an alpine mrv-m500 going at 500 RMS @2 OHMS. It is still in a small but ported box. I am planning to build a bigger box tuned low to achieve good output.
brains646 (06-14-19)
Old 04-15-20, 05:38 PM
iGotDat1UZ
iGotDat1UZ's Avatar
Default I found a headunit that can keep the factory subwoofer working
It's the Sony DSX-GS80. It has a direct subwoofer output (powered) because it has a 400w built in class D (efficient) amplifier. You wire channels 1 and 2 for the front and rear while reserving channel 3 and 4 to wire in parallel for the subwoofer to achieve a 2 ohm load.
Old 08-14-20, 06:29 AM
iGotDat1UZ
iGotDat1UZ's Avatar
Well, I hit a 140.2 dB with a single skar evl 12 on a taramps dsp 1600 with a J's 240a high output alternator
RAMAIR
11-26-22 11:18 AM
Blueshark
18
03-05-10 06:47 AM
pwrdbyrice
08-19-08 09:51 PM
TampaIS250
10-09-07 08:52 PM
kyle8744
13
07-23-04 09:00 AM
Quick Reply: Lexus Gs400 remote turn on wire
