2001 GS300 Misfires Under Load
10th Gear
Hello, all.
I'm new to this forum, my car is a 2001 GS300 with the 2JZ and auto tranny. Currently the car misfires under load, yet it purrs at idle. I get misfire codes PO303, PO305 and PO306, nothing leading me to conclusively say its ignition, fuel or timing.... The car has 228k miles on the clock.
As of right now, Ive replaced or fixed the following:
The spark plugs were replaced with NGK Iridiums (gap set to 44 thousandths)
The MAF was cleaned
Fixed any obvious vacuum leaks (replaced intake gaskets, fixed the intake muffler with some epoxy)
Replaced the timing belt, cam seals, water pump and fixed the vvti O-ring (I understand that I shouldn't have done this, but the O-ring was just absolutely puking. I put it together correctly.)
Replaced crank sensor
The coils are new (replaced before me, they are non-Toyota/Lexus brand)
The O2 sensors have been replaced in the past (non-Toyota/Lexus brand)
The dude before me also replaced the harness and connectors for the coils... But he just used stereo quick splice connections, so I got my soldering iron out and fixed those connections too.
I followed the harness back as well and fixed any broken wires or DAPO wiring fixes.
I replaced the alternator, and the battery is newer
I checked the ground connection to all the coils and spark plugs, and even added a chassis-head connection to improve the resistance reading.
Also, after replacing the spark plugs, the problem went away for a day then came back the following day.
I am now at a point where I do not know where to go next... Any ideas? Thanks in advance.
The MAF was cleaned
Gs300maste
06-10-19 10:22 PM
