Gs430 belt problem.
Gs430 belt problem.
I have a 03 GS430 and the accessory belt hit the ps pulley on the tensioner. I put on a new belt no change. I installed new tension pulley and idle pulley .And it's worse. I have a new PS pump and I did the timing belt so I went thru every thing. The pulley was rubbing before I did all off the work. Any suggestions?
What size of belt are you using? Too long maybe?
Dayco. Its the correct belt. The belt is mounted correctly . Is there a larger idle pulley. I want to say my orginal was larger but listed is the 2.97 in and i cant find larger.
I have a 01 GS430 and when i bought the car the Power Steering Pulley was making an awful sound and power steering was clearly not working as it should. Turned out the Power Steering Pulley was spinning freely on the shaft of the Power Steering Pump. Basically stripped Pulley AND stripped pump, so had to get all brand new ones.
Now this was possibly from previous owner installing incorrectly, who knows, but maybe you have a similar issue, I'm not sure. Keep us posted
There should be a pointer on the tensioner. Is it within the marks?
