My radio all of a sudden gets zero reception
I've had this car for a year now and the radio has always worked fine...
Drove to the gym today and it worked fine. After about an hour I started the car up to leave it was nothing but fuzz on every station both FM and AM. No music or anything. I tried to do a search but the radio wouldn't pick up anything, it'd just keeping looping through all the channels.
An areas I should start?
The main antenna is built in on the rear window and you could have a broken element that would affect the reception.
I recently have to replace my tint and in the process of removing the old film sections of the element got damaged, and most of my stations would not get signal. I took it back to the installer and he removed the film, repaired the element and applied new tint.
If your CD player is working then you have an issues with you antenna connections. Check your tape adaptor too.
JFNash
12-04-10 11:40 AM
