need helps on changing bolts on rotor
hey guys, i am getting a set of 10mm spacer for my front wheels, and i know i need a longer bolts on the rotors, does anyone have any experience of changing the bolts?
thx alot
thx alot
First remove your wheel, then remove the caliper by removing the 2 bolts on the back. Take off the rotor then you can extract the studs from the spindle. Install the new longer studs and reverse the order to put everything back together.
