Holes next to Spark Plugs, normal??
Found oil in the spark plug wells and thought it was due to a bad valve cover gasket install. I did it a couple years ago, but didn't notice these holes next to the top of the wells until now. All holes are on the intake side / driver side. There's no hole on top of #1, but it's everywhere else. Even between each spark plug. Are these normal? Should there be a seal inside that is missing? Or is it time to get a new car? 2002 gs300
In each picture, the holes are towards the top.
(Front) Only a hole on the left, which is plug 2.
(Mid) Circled one, but it's even on the middle
(Rear)
(Rear)
Yes those are meant to be there. There is a hole at the back of the head that those drain out of in case it was to flood in there. I don't know where your oil came from in the spark plug holes, but I'm pretty sure it didn't come from there. I'd suspect the valve cover still. It looks like it is wet in the upper left of the last pic you posted.
Bobafetti (04-27-20)
I had the same problem too, oil in the spark plug but don't have a gasket leak. Changed the gasket anyways. It's only been 100 miles and I'm too lazy to check the spark plugs well again. I might check it soon to see if there's oil in there again.
Not a chance.. you do only fill your oil to the mark on the dipstick right? The only way a dent in the oil pan could cause oil to come out of the top would be if the engine was completely filled to the brim of the fill cap, then the pan got hit, and oil forced out somewhere.
After finishing everything, it looks like it's leaking quite a bit in the front where the pulleys are. I'm thinking head gasket leak. Oh well. That will be for another time.
Thanks for everything guys!
Help
@TrueGS300 - So in the middle and rear one should have the same cutout slits in the same spot between plugs 3&4 and 5&6. I had the head done and never looked at it till now. Work was done years ago but just getting back around to it. Is that normal or would the builder for the head do that for a reason or did he mess up? He has been doing heads for 30-plus years and believe he made the heads for the first v12 2jz. People don't hate if it wasn't the first one I know he did it many years ago but that's not the point just want to know if they should be there. Just would like to make sure before I keep going on my build. Thank you
