Body Kiits
Body Kiits
Hey Everyone, so i just bought an 02 GS 300 and im planning on buying a body kit, but im having trouble finding poly-urethane kits and i have heard a lot of bad things about fiberglass kit regarding fitment and that they crack easily. I was wondering if y'all could drop some links to some poly-urethane options or some fiberglass kits if not some are not as bad as ive heard.
Pretty much all the high quality kits are fiberglass. A lot of bad ones are too, but almost all the good ones are fibreglass. It's true that it can crack if you drive into stuff, so don't drive into stuff with it. But since they are made from the original molds, from quality producers, they fit better. Also they can be worked on more easily by bodyshops, and can be repaired when they break (to some extent).
The TRD lip kit that was sold in Japan is made of ABS plastic, which is also a good alternative.
Another piece of advise is to not slam you car to the ground and expect a kit to last. If you're going for the VIP baller look, invest in an air suspension. It's the legit way to have a slammed ride, and get around without damage while raised to a safe height.
That’s All you need for a gs to look good is that kit, most gs300 kits look trashy, sept for the black diamonds kits but there like 7-10k for a kit and I like the kit world be worth more then most gs300 on earth.
