My gs 400 wont start
My 1999 gs 400 its been sitting for a year,i try to start it
it wont start, i hear the started going but wont start.no
ligths come on on speedometer either,it has gas
but it seems like the car is completly dead no ligths
breaks ligths either.can someone guide me the rigth
direction i love my car
Forum Administrator
You will need to provide more information to get any useful help, your post is way to generic.
what exactly is the car doing when you try to start it. Does it unlock and lock? Does the dash light up? Does the engine turn over but not catch? Does it just click when you try to start it?
Forum Administrator
I see you created another thread yesterday that has more detail. and I’ve merged it with this one
was you car on a trickle charger during that year? Did you have fuel stabilizer in the tank?
did you try a new battery or to jumpstart the car? That’s step one.
My. Gs wont start
Hi
fuel stabilizers?and no the battery was dead n its been there for that year,when i speay starting fluid tru intake
the car start ,but when the fluid is done the car shut off
when the car turn on for that moment still no ligths
on dash board or nothing.im going to go check the battery
today to see if i need a new one.thank you so much
for any advice .
for any advice .
Forum Administrator
Gas goes bad if it sits, if only a year it’ll likely work but sometimes can be the issue
start with a new battery. Be careful to keep the positive and negative straight and not mix them up when you replace it.
- It has been sitting for a year? If you really care about it, you probably should pull the plugs and pour a little oil into each cylinder to ensure there is some fresh lubricant on the cylinder walls and help the rings loosen up. I usually go this extra step when it’s a vehicle I care about, but it’s probably overkill for most people. Let it sit for a day if possible and be prepared for some smoke when u fire it up.
- And the gas will almost certainly be bad, it’s pretty hard to drain the gas on newer vehicles but depending on what the gas gauge reads, you can usually get away with adding at least the same amount of fresh gas, or more, and you’ll be able to get it to fire up and run, possibly a little rough til the bad gas is gone.
And I would advice u not to use starting fluid on anything more complex than a lawn mower. A fuel injected engine should fire up pretty quick if it’s got gas in it, and the battery is strong. Starter fluid can crack a piston if u get carried away with it. If it doesn’t start with a new battery and 5 gallons of fresh gas, then you probably have a bad fuel pump or something and will need to be diagnosed by a professional.
