Wiring diagram for 2001 gs430 with ML and no nav.
So I recently purchased said car and I'm tired of using 2001 technology in the factory radio. Also, my tuner **** only half works. I can change the radio station but I can't do much else like fade the speakers or increase the treble or bass. I read though the FAQ and there's nothing about my radio. I looked behind my glove box and I don't have an amp back there like all the other systems. I only have one factory amp, and it's in the trunk on the passenger side. Basically, what I'm asking is if anyone knows which wire is which, so I can bypass that amp and install a 4 channel amp and mono amp. If it helps the part number for my amp is 86280-0w030
Mark Levinson Amp
duhhh anyone else ?
duhhh anyone else ?
My experience is Aristo with Nav.
It is very different.
To figure out, use a 9 volt battety to find spkr wire pairs.
From thd Aristo, keep in ming that driver side speaker may pass through Nav system .
In thd Aristo we got a Jbl amp with one plug for the door and front center spkr (8 to 12 pins cant recall) and another for the sub but that sub plug carried s pair fof sokr output as well as apparently power to the amp. (4PINS)
I cant recall the input side if the amp.
I hope thix may help you.
RazorPC
05-31-18 03:31 AM
