I need help figuring out why my gs wont start
I went to the store and when i came out my car wont start it turns over strong its like it isnt get fuel or some thing is that any thing any one think sounds familiar that could help me
Angeldust (03-07-21)
If it cranks strong then I'd spray starting fluid into the throttle and have a helper crank it. If it starts, you have a fuel issue. If not, spark checkers are very cheap and you can check for spark the same way. Btw, is this the I6 or V8?
How many miles on the car?
One day my son's fuel pump quit. Like it started the day before but not that day. If I recall correct he said they typically quit around 200k miles. His had 250.
It took longer to remove the back seat than to replace the fuel pump. As in the fuel pump was not hard at all to change.
Same thing happened to me after a month of owning a 98 GS300. I had a parasitic draw and have resorted to leaving my negative battery cable disconnected until my multimeter arrives and I can verify what is drawing power when the car is turned off.
(Apologies for not introducing myself in the thread yet! Will do it by EOD!)
