Suspension replacement
Hey guys, new member here. I just have a question about my 98 GS400. I lost traction the other day and bumped my right rear wheel against a curb, bending it. However, after taking a look at the control arms and linkages, they don't look bent, but that might just be me. Do I only need to replace the knuckle, or is there something else I should fix?
Subframe bolts:
Before:
You should start by replacing the rim and have the alignment checked if there are no other visual issues. If the camber and tow can be brought in with the factory bolts/arms you're good. Or at least matched to the other side since I see you have coilovers. If it's out, you will get recommendations from the technician. You may need a bearing replacement if you hear grinding noises after the hit too.
That looks really bad. There must be something bent.. No surprise the tire blew out. It's scrubbing hard.
Yeah, it's my daily and with the taller spare on right now i'm probably driving at a ~20-30° angle right now. I've been trying to find out what parts i'm going to need to buy but everything looks relatively straight. I'm going to try and mess with the toe link when I replace the wheels, hopefully that helps a little bit for now.
