IAT Sensor Mod
IAT Sensor Mod
Hi can anyone help me locate the correct wire on the IAT to do the resistor mod it's on a 1998 GS300 I know its the plug going in to the intake tube but it has multi wires and im not sure witch ones I should use.
Any help would be GREAT
Thanks
James
Thanks
James
Master Thread Closer!!
I dont think any CL members did this mod cuz all says its B.S....so you may not get any replies.
I'd suggest you email the ppl you bought it from for assistance.
Curious, if you feel any HP or torque gains, or Not.
Pete
Pete
If anything,
this mod would only add or subtract fuel across the rpm / maf signal...
at colder intake temperatures, the computer is programmed to give more fuel...
why? because colder air temperature = more dense o2 makeup...
more o2 + more fuel = more power....
but, with the IAT mod... you would be fooling around with the computer's
original programming...
if anything, an APEXi S-AFC or HKS AFR would be a better choice
than fooling with the IAT signal...
running too rich or running too lean... doesn't = power....
running perfect A/F ratios = power
VSsc400
RX - 1st Gen (1999-2003)
12-28-04 07:57 AM
