Leaky gas tank or fuel filler neck?
Hello folks, got a bit of a new issue now. After filling my tank about 2 days ago, I noticed occasionally I would smell gas. Was about to do the exhaust when I noticed fuel stains at the bottom front of the tank, drivers side, around the area where the seam between the bottom and top halves is. So my first thought is that the tank seams are leaking, but what is even more strange is that there is some fuel stains (and wet fuel) just above the seam, and farther back there are stains as though it is coming from up top somewhere. Since I did just fill the tank up a day or two ago, I suspect the fuel filler neck being leaky (or the seam between the fuel filler neck and the tank itself). I'll provide some pictures when I can. Thanks to anybody who can help!
Nope, not at all. Partially why I am confused as well. The leak is very, very small. Over the course of 2 days there is hardly anything collected on the seam at all, no drips or anything, just hardly enough to get your fingers damp. And, it isn't water, its definitely fuel.
EDIT: Also, the area around the fuel filler neck is intact. No leakage there whatsoever.
My main dilemma now is how to fix this. I know the leak is coming from the rear of the tank, and taking the tank out would be impossible as the exhaust is rusty and the gas tank straps bolts are INCREDIBLY rusty, any attempt to take them off would result in... well lets just say, adios bolt. I know about an external spray sealant, similar to that of Flex Seal but resistant to petroleum and things. I believe it is called Permatex spray sealant. If anybody could provide information on some sort of spray sealant that is resistant to petroleum, please do.
How many miles do you have on your GS and the location? I'm curious. I would probably try the spray sealant and see if that would hold up. The worst case scenario, you probably have to bite the bullet and drop everything to replace the tank. Might get very expensive for what it is, and that's the only thing.
If that happens to mine, I'd just patch the leak by leak since mine is high mileage.
So, both good news and bad news. Sprayed some purple power onto the top area of the tank, and went to sand when I realized there is actually a rubber coating up top, and the holes I believed I had found were just rips in the rubber coating (strange?) and thanks to Purple Power, it started flaking off. Got all of it in the area off, noticed that the rubber that sat around the fuel filler neck end and press-plate smelled like gas also. If you look closely there appears to be a tab that is bent, indicating somebody was tinkering with this before.
The top red circle is the tab that appears to be bent. The rubber coating that was around the fuel filler neck stank like gasoline. After removal of the rubber coating, the smell of gasoline faded until I sprayed it down with water, uncovering the holes (two lower circles) of which then began to stink like gas. Going to let it dry and come back later today to sand some more and put SteelStik on it.
Hoping your patch job would hold up for a long time. I would only assume that those products went through numbers of strict testing done to be on the market. It might hold up for your car's lifetime. Keep us updated with results.
So after I checked for the spray sealant, I noticed it never said it was resistant to gasoline. That's when I started seeing ads everywhere for PERMATEX SPRAY GASKET. Literally, spray gasket. turns out it can be used as a spray sealant or as a spray gasket (as the name suggests) AND it's resistant to gasoline. If the SteelStik fails or if there is a leak in another location, I'll buy the Permatex spray gasket, scrape up the old flex seal and spray it on. I will update probably in the next month or two or if the tank starts leaking. Wish me luck!
stevelifts
06-05-17 09:44 PM
