98 GS400 Speedo lights
Hi, I purchased this 98 super clean GS 400 about two weeks ago and has been very good to me but in this picture is cruising at highway speed‘s on multiple occasions my speedo in these lights of come on. Any advise is welcome
That indicates a problem with the ABS, braking, or VCS systems, possibly a combination of all three.
The red "BRAKE" light really is only supposed to illuminate when the fluid level is low, the parking brake is on, or there's some other catastrophic brake system failure.
Either way, if the car is appearing to drive normally, take the car to someone/somewhere that has a full-system OBD-II reader to get the codes and find out what's wrong. Your average off-the-shelf scan tool won't show brake system codes.
You also have a fault in your air-bag system, which you should probably get checked out as well.
Were you intentionally revving the car in the picture? The idle is way too high.
I often take mine to a Lexus dealer's service department, pay them the $100 diagnostic fee, and let them tell me everything that's wrong with it, then find cheaper solutions elsewhere.
Then your speedometer obviously doesn't work either. Sounds like your car has got a plethora of issues; more than any one of us is going to be able to diagnose over the internet.
Actually, those VSC and ABS lights could be caused by a faulty rear wheel speed sensor. The gauge cluster ECU is fed speed information by the ABS/VSC/TC ECU, of which gets the speedometer readings off of the rear wheels. If a rear wheel speed sensor is malfunctioning, your speedometer won't work either.
Also, if the transmission speed sensor would go wrong, you would probably end up with the transmission not shifting at all, or shifting incredibly erratically. It would essentially be shifting blind.
CSHFLW
04-10-02 11:22 PM
